Hello all,
I have a problem with a clone of the standard 'arcgispro-py3' environment.
I am working with ArcGIS Pro 3.0.5. As I am employed the device is owned and managed by the company, which leaves no way of changing the ArcGIS installation.
However, to gain some freedome in the use of 'arcpy', I do create clones of the standard environment. Therefore, I go to the directory that contains the 'conda'-related scripts and clone the environment in the C:\Program\ArcGIS\Pro\bin\Python\envs
to
C:\Users\*\AppData\*\envs.
I do create a clone in order to install the 'esda' package which conveniently comes with 'libpysal', that I also need. Now, to prevent any major hiccups and knowing the issue that comes up, I do pin the ‘gdal’ to 3.4.0.
I perform all installations of packages in cloned environments through the command line and the ‘conda’-related scripts.
I have a .pyt based Toolbox, that uses subscripts. These should employ ‘gdal’, ‘esda’, and ‘libpysal’.
What I tested:
- Clone environment, NOT installing ‘esda’ and ‘libpysal’, disabling the sections in the script that need these, and disabling the ‘import’ of said packages.
‘from osgeo import gdal’ is used.
Then, said toolbox and script can be run over and over, within one session of ArcGIS Pro, or closing Pro and opening Pro again.
The cloned environment and all package dependencies are stable. - Installing ‘esda’ and ‘libpysal’ (while ArcGIS Pro can be opened or closed).
gdal 3.4.0-arcgispro_py39_17119 --> 3.4.0-arcgispro_py39_17150
This happens along with the otherwise flawless installation.
I enable the sections of the script that use ‘esda’ and ‘libpysal’ functionality, ‘import’ the packages.
Also, ‘from osgeo import gdal’ is used.
Then I (start ArcGIS Pro and) open the toolbox, the syntax check is successful, NO errors.
The toolbox can be used again and again.
But, if I now close ArcGIS Pro (the day might be over), and then come back to it and want to use the Toolbox, I get an error:
File "C:\Users\schwenk_m\AppData\Local\ESRI\conda\envs\MSdev39ArcPy\Lib\site-packages\osgeo\__init__.py", line 40, in swig_import_helper
return importlib.import_module(mname)
File "C:\Users\schwenk_m\AppData\Local\ESRI\conda\envs\MSdev39ArcPy\Lib\importlib\__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 666, in _load_unlocked
File "<frozen importlib._bootstrap>", line 565, in module_from_spec
File "<frozen importlib._bootstrap_external>", line 1173, in create_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
ImportError: DLL load failed while importing _gdal: Die angegebene Prozedur wurde nicht gefunden.
During handling of the above exception, another exception occurred:
File "<string>", line 17, in <module>
File "C:\Users\schwenk_m\Documents\ArcGIS\Projects\Geo_gen\RasterSurfaceAnalysis.py", line 23, in <module>
File "C:\Users\schwenk_m\AppData\Local\ESRI\conda\envs\MSdev39ArcPy\Lib\site-packages\osgeo\__init__.py", line 56, in <module>
_gdal = swig_import_helper()
File "C:\Users\schwenk_m\AppData\Local\ESRI\conda\envs\MSdev39ArcPy\Lib\site-packages\osgeo\__init__.py", line 52, in swig_import_helper
raise ImportError(traceback_string + '\n' + msg)
ImportError: Traceback (most recent call last):
On Windows, with Python >= 3.8, DLLs are no longer imported from the PATH.
If gdalXXX.dll is in the PATH, then set the USE_PATH_FOR_GDAL_PYTHON=YES environment variable
to feed the PATH into os.add_dll_directory().
My questions is, what happend to the environment through the installation of the new packages, and by closing and opening ArcGIS Pro?
For all that I tryed, I could not, as suggested, set the option 'USE_PATH_FOR_GDAL_PYTHON=YES'.
I did not grasp how to exactly use the command
conda env config vars list
that was suggested here. However, I did add the line to the '.condarc' file in my Home directory, which does not help.
Furthermore, upon inspection all the .py scripts related to GDAL in the OSGEO folder are still there.
I am thankful for any pointers.
