Connecting to SQL Server 2012 from ArcGIS Pro
736
5
11-16-2016 11:25 AM
SamMontoia1
I am attempting to Connect to an instance of an enterprise database (SQL Server database), but I get the above error message in Pro, but the same connection works just fine in Desktop or Catalog.
I am using Operating system Authentication.  64-bit server, SQL Server 2012
Microsoft SQL Server Management Studio 11.0.2100.60
Microsoft Data Access Components (MDAC) 6.1.7601.17514
Microsoft MSXML 3.0 4.0 5.0 6.0
Microsoft Internet Explorer 9.11.9600.17633
Microsoft .NET Framework 4.0.30319.42000
Operating System 6.1.7601
JeffWard
I'm running into this issue. Was there a solution? Is it not possible to connect to a SQL Server 2012 SDE database?
Jeff Ward
Summit County, Utah
George_Thompson
Esri Frequent Contributor
What version of Pro are you using @JeffWard ?
--- George T.
JeffWard
3.1.2
Jeff Ward
Summit County, Utah
George_Thompson
Yeah, I would say that SQL 2012 is not supported on that version of Pro; https://enterprise.arcgis.com/en/system-requirements/latest/windows/database-requirements-sqlserver....
The "oldest" version of SQL Server supported is 2016. Even Pro 2.8.x does not support SQL 2012.
SQL Server 2012 is not supported by MS anymore: https://learn.microsoft.com/en-us/lifecycle/announcements/sql-server-2012-windows-server-2012-2012-r...
I would recommend moving to a more modern SQL Server version, like 2019 or 2022.
--- George T.
JeffWard
Thanks @George_Thompson , I'm looking at moving our database to another server. The one it is on now can't be updated due to other systems relying on it. Thanks for your help.
Jeff Ward
Summit County, Utah
