Using ArcGIS Pro 2.2.4. I'm converting a date time field of format yyyyMMddHHmm into the Date format.
Why does the resultant output contain only dates and not times?
I added some additional rows containing odd times "1402" "2223" and it does the same thing.
The input files are from the Storm Prevention branch of the National Weather Service. www.spc.noaa.gov/products/outlook/day1otlk-shp.zip
I also added a field, ran a field calculation script to change the input to MM/dd/yyyy HHmm format and ran Convert TIme Field on the new field with the same results of dates being converted but not times.
I viewed the help file but nothing mentions dropped time values.
