Correct, not implemented yet.
In the meantime, one way to get around that limitation is to create data frame grids/graticules in ArcMap, convert them to graphics and import the mxd/layout. Of course, that means they will be static graphics.
Alternatively, you should also be able to use grid and graticule layers, which are features layers and so should work just like any other feature layer.
