Hi
In arcgis latest update (2.3.3) Create Scene Layer tool, was split into several specific. One of those is Create 3D Object Layer Package, which throws an "ERROR 002102 Unsupported properties set in the layer" when I try to export a layer with its Elevation setting "On the ground" or "Relative to the ground". It allows the export only with the option "At an absolute height".
However the previous generic tool in older versions, would export the layer with no complains.
Is this normal or is there an issue with the new tool?
Thank you.
