Hey guys! I created that sql expression below in Create Database View to simplify the users queries and it worked well, but I've acrossed with some issues.
When I made join i lost the fields subtype_codes. Then, it remains just the associated default value.
Is there a way to conserve subtype_code after doing that join tables?
SELECT adhp.name_txt, adhp.type_code, adhp.military_code, adhpsurfacearea.subtypecode, adhpsurfacearea.globalid, adhpsurfacearea.length_val, surfacecharacteristic.composition_code FROM adhp JOIN adhpsurfacearea ON adhp.gfid = adhpsurfacearea.adhp_id JOIN surfacecharacteristic ON surfacecharacteristic.gfid = adhpsurfacearea.surfacecharacteristic_id;
In this case, the field is subtype_code from adhpsurfacearea.
Thanks in advance.
