Dear all
I am a brand new user and would ask kindly for help.
I would like to upload the population of switzerland for each municipality into a map from an excel file.
Unfortunately this is not possible, because it seems, that ArcGis cannot use the name of the municipality as a geografic entity. But i neither got the shapes nor the polygons of each municipality. Which source delivers the attributes for each municipality and how can i use the attributes correct?
Following Error messages are being displayed:
Startzeit: Samstag, 4. Februar 2017 20:08:02
ERROR 000339: Eingabe 2015 (2)$ hat keine OIDs.
Fehler beim Ausführen von (SelectLayerByAttribute).
Fehlgeschlagen am Samstag, 4. Februar 2017 20:08:02 (Verstrichene Zeit: 0.17 Sekunden)
I tried to convert the data and this was the error message:
Startzeit: Samstag, 4. Februar 2017 20:09:26
Skript ExcelToTable wird ausgeführt...
Failed script ExcelToTable...
File "c:\program files\arcgis\pro\Resources\ArcToolbox\Scripts\ExcelToTable.py", line 265, in <module>
arcpy.GetParameterAsText(2))
File "c:\program files\arcgis\pro\Resources\ArcToolbox\Scripts\ExcelToTable.py", line 235, in excel_to_table
template=tmp_table)
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 14933, in CreateTable
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 14930, in CreateTable
retval = convertArcObjectToPythonObject(gp.CreateTable_management(*gp_fixargs((out_path, out_name, template, config_keyword), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 000354: Der Name enthält ungültige Zeichen.
Fehler beim Ausführen von (CreateTable).
Fehler beim Ausführen von (ExcelToTable).
Any ideas, videos and or solutions?
Many thanks Jan
