HI Team,
I need to write simple commandline tool to read the file geodatabase (.gdb) containing Utility network and all its feature classes.
I got confused, which SDK should i need to use to achieve this. I understood that if i use ArcGIS map SDK, then i need to convert file geodatabase to mobile geodatabase (.geodatabase). I would like to avoid this.
1. Can I use ArcGIS Pro SDk for reading this GDB file?
2. I dont want to add this command line utility as Add-in to ArcGIS pro, i should use this as a separate commandline utility. Can i still use ArcGIS Pro SDK for this.
