I am trying to run a Dissolve in ModelBuilder, but it is only allowing me to select numeric fields for both the dissolve field and statistics fields. I tried configuring the tool straight through the geoprocessing toolbox using the same input dataset, and all my text fields are showing up, but when I try it in ModelBuilder it only allows me to select the numeric fields. Even if I search one of the text fields it won't show up.
This is what I see when I configure in the geoprocessing pane:
And this is what I see when I configure the tool through ModelBuilder on the same dataset:
Has anyone else had this problem? Am I doing something wrong or is this a glitch? I am operating on Pro 3.1 (waiting for my IT department to install 3.2, hoping that may be the fix?)
