Domain Coded Values or Manual Entry
450
06-15-2022 09:58 AM
JorgeKappa
Is it possible to create a domain where the user can pick a coded value or enter a non coded value manually?
TIA
JohannesLindner
MVP Frequent Contributor
AFAIK, it's not possible to change the manual editing workflow to "select one of the domain codes or type in your own value".
But you can insert features with "wrong" values using Python (and probably Arcade, though I haven't tested that):
with arcpy.da.InsertCursor("Table", ["Field"]) as cursor:
    cursor.insertRow([5])  # Coded Value Domain [0, 1]
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
JorgeKappa
Thank you, Johannes. This is clever. Not something the guys in the field could do, but clever nevertheless.
