Hello everybody,
I'm trying to draw polygons based on coordinate information in a table. Each polygon consists of four vertices, and the table contains 8 attributes that store the x- and y-coordinate of every vertice separately. The table also contains other attributes I'm trying to take over to the polygon attribute table. Is there a way to directly convert the table to a polygon feature? Here's a screenshot of the table so you can get an idea:
So e.g. P1X stores the x-coordinate for point 1, and P1Y has the y-coordinate for point 1 and so on. Every row represents a polygon consisting of four vertices.
I know of the tool XY table to point and that one could theoretically then turn those points into polygons by hand, but that does not allow me to retain the other attributes. Is there a tool I'm unaware of that turns coordinates into polygons directly?
Thanks in advance for your help, every hint is appreciated!
-Moritz
PS: I'm working on ArcGIS Pro 2.9.2
