Error running Add Spatial Join tool more than once on same target layer
391
12-27-2023 11:50 AM
Labels (3)
josh_is_fine
*UPDATE*:
Confirmed BUG by ESRI: BUG-000164073
Description:
Add Spatial Join tool fails on subsequent runs when attempted on same target layer.
Steps to Reproduce:
  1. Run Add Spatial Join successfully on a target layer.
  2. Remove all joins from the target layer.
  3. Attempt to run Add Spatial Join again on the same target layer.
Observed Behavior:
Receive error "ERROR 000210: Cannot create output C:\Users\...\scratch.gdb\target_layer_AddSpatialJoin".
Expected Behavior:
  • The Add Spatial Join tool should run successfully again on the same target layer.
  • Or at least display a warning if the issue is related to the formatting of the layer name.
Notes:
  • Issue persists after restarting ArcGIS Pro or re-adding layers.
  • Seems related to special characters in layer names (e.g. periods in naming format: "Layer.Name").
  • Can work around by removing special characters from target layer name before re-running tool.
  • This is mainly an issue when creating automation tools, as the user would usually not have the option to alter the target layer name.
Environment:
  • ArcGIS Pro 3.1.3
  • Windows 10 Enterprise 21H2
DanPatterson
Can't reproduce using Pro 3.2 and the add spatial join and remove joins from ArcToolbox
... sort of retired...
josh_is_fine
Good to know, thanks Dan
