Export Features with Table Join - Field Mapping (v3.2)
948
16
11-21-2023 08:54 AM
Andy_CS
In Pro 3.2 -- When running the Export Features tool on a feature layer with a table join (validated 1-1) the field map is stating that the fields from the join table have two source fields and it looks like the source field is being duplicated in the dialog. Anyone else seeing this? Export works as expected (action is set to First) I just think it's a little odd.
In Pro 3.1 I just get one source field which is what I'm expecting.
DarylHochhalter
Occasional Contributor II
KyleKirkman1
I have the same damming failures in PRO 3.2.0, 3.2.1. It trashed all my Modelbuilder processes and I reverted back to 3.1.4 -   I'm staying off 3.2.x till 3.2.3,4,5 or whenever things might be fixed.
DarylHochhalter
When you uninstalled 3.2 did you have any issues with losing favorites or project setting etc.?
JaronJensen7
I just updated to 3.2.2 and it seems to have fixed my problem with my model not remembering my field map in the Export Feature/Table tool. I did work with ESRI and they told me that a fix would be coming in 3.3 but they couldn't tell me when that would happen, just that it will probably be the next update to come to ArcGIS Pro.
PaoloBasile_ST
Are you sure Jaron? I have 3.2.2 and unfortunately I always encounter the same bug...
JaronJensen7
Yeah mine is working. Im not sure what is going on. I do still have an issue with the field map when I run a model that has some spatial joins before running the export. It wants to put the same field in twice and it causes it to fail. So I have to run that part of the process, refresh the map field, and then I can just validate and run the whole model.
DarylHochhalter
I finally just went back to 3.1 after having some other issues related to lyrx files and not being able to access them through arcpy, possibly because they had joins in them too???
