Exporting map in ArcGIS Pro without sources?
881
07-13-2017 06:00 PM
IsaacZukin
I am currently exporting a map (inside a layout) in ArcGIS pro. As you know, when you insert a map into a layout the sources for the map appear. I am fine having the sources there but is there any way to minimize their size? I am using this map for a very specific layout to be published and the text absolutely overpowers the image. Thanks!
IsaacZukin
Solved! I went insert->dynamic text>Service Layer Credits. Then I changed the text for the service credit to no color. Worked for me!
IsaacZukin
