Hello LR2,
The names are going to be truncated and this is to avoid issues on enterprise database. The feature classes generated by the tool will be named based on the following rule.
Category_"DatasetName"
In this Example I did not modified the dataset name that the tool generated and accepted the default name which is Admin_BLDG_DA_vr12_2020_BIMF (28 characters).
The resulting feature classes will be name
Casework_Admin_BLDG_DA_vr12_2020_BIMF
For the fails I will need more information.
* What are you trying to do?
* Which version of Pro are you using ?
* Which version of Revit are you using as in input ? ( 2017, 2018, 2019, 2020 or 2021)
* Is this a new database or one that already has data on it ?
David
