Just about sent a map set out, then realized the buffer distances seemed way off (pink, below). I had entered the distances correctly and the coordinate system of the input points was in the coordinates I had assumed. I reran, changing nothing except using 'Planar' and it was correct (blue, below). Geodesic is the default. Is this a bug? is there something that causes this to happen that I should know about?
Thank you,
Randy McGregor
