Georeferencing
2109
05-23-2016 12:58 PM
AmeliaNewsam
I see that ArcGIS Pro does not have the georeferencing tool.  Are there any workarounds?  I have a CAD map with no coordinate system defined, and no matter what coordinate system I try for the Map frame, it ends up in the middle of the Pacific Ocean.
DanPatterson_Retired
since you have pro, you also have arcmap I presume, the current workaround is to do the georeferencing there and port the result, which is no big deal. Consider Pro a work in pro-gress
PS  for cad files, you are using a relative coordinate system I bet (ie 0,0 coordinate origin), you will have to adjust your coordinates using Spatial Adjustment tools to move the origin... projection will do nothing, nor will defining the coordinate system. the data has to be given a new origin, and hopefully the adjustment can be done from or during that process.
AmeliaNewsam
OK, thanks!
AmeliaNewsam
OK, that's what I was suspecting. Thanks so much!
