In Arc Pro:
every time I create a new polygon and attempt to calculate the geometry
arc just "works" on it forever.
I have let it run up to 30 minutes once just to see... no avail
the tool running does not cancel and does not allow the program to close.
The only thing I can do to fix this is end the task through task manager and restart the entire arc pro.
Please if you have an idea what might be causing this/possible solution let me know.
Thank you
Sincerely,
Christopher
Esri Technical Support
#bug
