I am using hillshades to identify ditches. The parameters proposed to me when starting this was:
Azimuth=315
Altitude=25
Z factor=2
After a while I got a feeling the visibility of ditchlines varied alot depending on its position to the light. Ditches going parallell with lightsource is really hard to see but when in an 90 degree angle to light ditchlines is easily seen. This makes sense to me...but I realize I probably would be better off with multidirectional hillshade rather than to look at same areas with different hillshadelayers.
What doesnt make sense to me at all is that when I began experimenting with different Azimuth for same areas I suddenly saw the ditch as a ridge rather than a depression... Can anyone explain to me why this is happening? And if someone with experience of multidirectional hillshades could assure me that this cannot happen with that method it would be a great relief!
The attached pictures are the same are in Azimuth 90, 270 and 315. The one with Azimuth 90 is the one I find strange, no matter direction of light depressions should not become a ridge?
Solved! Go to Solution.
The "ridge" appearance is just an optical illusion. If you rotate your screenshots in any image viewer, you'll see the ridge magically become a gully.
azimuth, z-value and elevation combinations will all influence the hillshade and can create artifacts in the result. There is a vast array of literature out there on hillshades and what they can and can't do and what can result with varying the parameters. The default values aren't magic, they are a compromise based on how we visualize things and what our eyes expect.
Enter the multidirectional hillshade
Hillshade function—ArcGIS Pro | Documentation
Give it a try
Thanx for excellent feedback! I will experiment further!
Try a red relief image map. It is amazing. It looks like a hillshade, but it's not. No compromises with regard to the illumination angle. Excellent for interpreting relief:
See one or more of
You can get the raster functions you need from the Relief Visualization Toolkit at https://github.com/EarthObservation/rvt-arcgis-pro
