I need to link points that have only X,Y coordinates (without elevation) with a Delaunay triangulation. However, when I use "Create TIN", it shows a error message and don't create what I need. Any suggestions?
Thanks and regards!
Free advanced tools -Thiessen Polygons Delaunay Tr... - Esri Community
might work for you
Thanks for your reply and your help! I've downloaded the files and tried to use the toolbox; however, as I'm using ArcGIS Pro 2.9, it won't work, right? I've got some error messages:
" Traceback (most recent call last):
File "C:\PythonStart\tbx_tools.py", line 810, in <module>
elif tool in ['Bounding Circles', 'Convex Hulls', 'Extent Polys',
File "C:\PythonStart\tbx_tools.py", line 801, in _tool_
all_flds = cls_flds + [stat_fld]
File "C:\PythonStart\tbx_tools.py", line 755, in pick_tool
# tbx = ImportToolbox(tbx)
File "C:\PythonStart\tbx_tools.py", line 577, in tri_poly
out_kind = shp_kind
File "C:\PythonStart\tbx_tools.py", line 219, in _in_
r"""Check file name and file path for compliance.
File "C:\PythonStart\npg\npg_arc_npg.py", line 285, in fc_to_Geo
cols = IFT_.shape[0]
UnboundLocalError: local variable 'IFT_' referenced before assignment
Failed script Delaunay...
Failed to execute (Triangulate)."
