How to use ArcGIS Pro with SQLite
10343
20
01-30-2015 02:44 AM
LarsLarsen
As far as I can see there is no direct support for SQLLite in Pro. Is that a planned feature ? Can I access SQLite through phyton and import data as layers that way?
BradleyAndrick3
Is there any update on this? I would like to open a sqlite geodatabase (a ".geodatabase" file) in ArcMap or ArcGIS Pro. Is this possible?
Brad
LanceShipman
Sqlite, SpatiaLite and GeoPackages are supported in Pro. Mobile Geodatabases (.geodatabase) support is being considered for a later release, but not in the Pro 2.1 currently under development.
Lance
JoshuaBixby
I think mobile geodatabases (.geodatabase) are great, SQLite meets geodatabase.  Does Esri have plans to support native access within the desktop clients instead of having to convert back and forth between file geodatabases?
MalcolmMeyer
Confirmed. I have successfully created both a Spatialite and GeoPackage database. However, I cannot edit the data...getting a 'not registered in the Database' error. I try to register the data and that also errors out. Is it possible to edit SQLite databases in Pro, and if so how does one do this?
LanceShipman
Editing SQLite data is not currently supported in ArcMap or Pro. We are looking at it for a later (post 2.1) release.
Lance
MalcolmMeyer
Great. It would be helpful to have that clarified either here - Supported data types and items—ArcGIS Pro | ArcGIS Desktop  or here - Work with SQLite databases in ArcGIS Pro—Help | ArcGIS Desktop, would have saved me asking in this forum.
AZendel
Still doesn't look like SQLite is editable in Pro 2.3. Any news/speculation about future releases?
ThomasColson
MVP Frequent Contributor
I don't think there's going to be any rush for sqlite support anytime soon. Many organizations are blocking it from the network, too many security holes.
https://www.cvedetails.com/vendor/9237/Sqlite.html
JoshuaBixby
Let's not advertise then that GeoPackage is built on top of SQLite.
In defense of SQLite, it isn't any more prone to issues than most software, and the group behind SQLite does address vulnerabilities fairly quickly.  If having CVE entries was sufficient to block software from the network, I am not sure how many applications would remain on the network.
ThomasColson
There was something specific about one of the entries, and how it was fixed (or not), that put it in "jail".
