Hello All,
ArcGIS Pro 3.2
My database was built in ArcMap over many years. I have a feature class with a text field "Addressfile". This, unsurprisingly, is a point file feature class that has supplementary info hyperlinked to the feature, such as photos, and asbuilts. The hyperlinks are activated by the "thunderbolt icon" in ArcMap. The destination for the links in Arcmap are folders in a shared drive particular to each address with pathways in the UNC syntax. The destinations are copy-pasted and scripted from my network drive in Windows File Explorer. The link is active and opens all data for the entire feature class when using ArcMap.
I have started to migrate to ArcGIS 3.2. None of these links works in ArcGIS Pro, and I haven't found a similar feature to the hyperlink thunderbolt as is available in ArcMap. Is it possible to link to a folder on a shared network drive in Arcgis Pro, or do all hyperlinks need a file extension, i.e. .pdf, .jpeg?
Thanks very much for any suggestions
