Import Map Fails - "LoadLibrary failed with error 126: The module could not be found"
1596
6
06-29-2021 08:13 AM
Labels (2)
ThomasM
I'm using Pro 2.8.1 and attempting to import an mxd. The process immediately fails and I get an error saying "LoadLibrary failed with error 126: The module could not be found." When I close the error, it shuts down Pro.
I have a coworker still using 2.8.0 that has no issues running the import and another coworker using 2.8.1 that gets the same error that I do. I've tried multiple, simple MXDs with the same error every time.
The information I've been able to find about the error (not Arc-specific, I can't find any reference to this issue on anything ERSI-related) makes it sound like it only happens when using a program on a remote session, but I'm working locally.
GIS Specialist - MO Office of Geospatial Information
ThomasM
I was able to fix this issue by disabling my AMD Radeon graphics card. Seems like the issue may have nothing to do with Pro, just a less-than-stellar graphics card.
JayantaPoddar
Does this issue occur with a specific MXD or multiple MXDs.
Please connect with the Esri Technical support.
If the issue is reproducible, they may log a bug.
Think Location
ThomasM
I tried several MXDs and had the same issue with all of them, as did my coworker.
Robert_LeClair
Esri Notable Contributor
To test if it's a 2.8.1 issue, you can go to Control Panel, Uninstall a program and click on View installed updates.  Select and uninstall ArcGIS Pro 2.8.1 update and try your workflow again.  If the *.mxd imports correctly, then it may be an issue with the 2.8.1 update.  You can then log this as a BUG with Esri Technical Support as @JayantaPoddar mentioned.
ThomasM
On your advice, I rolled back the update to 2.8.0, and the problem persisted. So I completely unistalled Pro, removed all associated folders in my user/local and roaming folders, and did a clean install of 2.8.0. The issue is still there, which leads me to believe the issue is something with my computer and not Pro, but I'm at a loss as to how to fix it.
ThomasM
ChelseaRozek
MVP Regular Contributor
Thanks, that fixed it for one of my users. She was the only one having this problem, even after upgrading to 2.9
