Here's what happened:
- Made clone of arcgispro-py3 default env
- Entered conda install dbfread
- Got this warning
The environment is inconsistent, please check the package plan carefully
The following packages are causing the inconsistency:
- esri/win-64::arcgis==2.1.0.2=py39_14
- esri/win-64::arcpy==3.1=py39_arcgispro_41759
- esri/noarch::dask==2022.7.0=py_0
- defaults/win-64::distributed==2022.7.0=py39haa95532_0
- esri/noarch::ipykernel==6.16.0=py_1
- esri/noarch::ipywidgets==7.7.2=py_0
- esri/noarch::jupyterlab==3.4.8=py_0
- esri/noarch::jupyterlab_server==2.16.0=py_1
- esri/noarch::jupyter_client==6.1.12=py_0
- esri/noarch::jupyter_console==6.4.2=py_0
- esri/noarch::jupyter_contrib_core==0.4.0=py_0
- esri/noarch::jupyter_contrib_nbextensions==0.6.0=py_2
- esri/win-64::jupyter_core==4.6.3=py36_2
- esri/noarch::jupyter_highlight_selected_word==0.2.0=py_4
- esri/noarch::jupyter_latex_envs==1.4.6=py_5
- esri/noarch::jupyter_nbextensions_configurator==0.4.1=py_3
- esri/noarch::jupyter_server==1.21.0=py_0
- esri/noarch::nbclassic==0.4.8=py_0
- esri/noarch::nbclient==0.7.0=py_3
- esri/noarch::nbconvert==7.2.1=py_2
- esri/noarch::nbformat==5.6.1=py_0
- esri/noarch::notebook==6.4.12=py_0
- esri/noarch::notebook-shim==0.1.0=py_0
- esri/win-64::pro_notebook_integration==3.1=py39_12
done
## Package Plan ##
environment location: C:\Users\dconly\AppData\Local\ESRI\conda\envs\arcgispro-test
added / updated specs:
- dbfread
The following NEW packages will be INSTALLED:
dbfread pkgs/main/noarch::dbfread-2.0.7-pyhd3eb1b0_0
pywin32 pkgs/main/win-64::pywin32-305-py39h2bbff1b_0
The following packages will be UPDATED:
ca-certificates 2020.7.22-0 --> 2023.01.10-haa95532_0
certifi 2022.9.24-py39haa95532_0 --> 2023.5.7-py39haa95532_0
jupyter_core esri::jupyter_core-4.6.3-py36_2 --> pkgs/main::jupyter_core-5.3.0-py39haa95532_0
python esri::python-3.9.16-0 --> pkgs/main::python-3.9.16-h6244533_2
The following packages will be SUPERSEDED by a higher-priority channel:
openssl esri::openssl-3.0.7-0 --> pkgs/main::openssl-1.1.1t-h2bbff1b_0
I chose to ignore the error and proceed with the install. But after installing and trying to import arcpy, I get this error:
>>> import arcpy
File "<stdin>", line 1, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 77, in <module>
from arcpy.geoprocessing import gp
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\__init__.py", line 14, in <module>
from ._base import *
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 14, in <module>
import arcgisscripting
File "C:\Users\dconly\AppData\Local\ESRI\conda\envs\arcgispro-test2\lib\site-packages\arcgisscripting\__init__.py", line 131, in <module>
from ._arcgisscripting import *
ImportError: DLL load failed while importing _arcgisscripting: The specified module could not be found.
This error did not happen prior to installing dbfread. Based on this March 2023 post and this August 2022 post, I figured it might have been related to not installing from the correct conda channel. But in the past I've installed dbfread in environments in this manner without any effects on arcpy. But for your all's information, here's the info on the dbfread install:
# packages in environment at C:\Users\dconly\AppData\Local\ESRI\conda\envs\arcgispro-test2:
# Name Version Build Channel
dbfread 2.0.7 pyhd3eb1b0_0
Other observations:
- I'm using Pro 3.1
- This issue doesn't seem to care what package I'm installing (I use dbfread as an example, but it also affected me for geopandas).
Any idea what's going on?
