Is it possible to navigate and visualize the geometry below the ground level In ArcGIS?
602
06-26-2020 01:46 AM
ShreeP
We have some models which are below the ground level. Let's imagine an underground story/parking building. Can we visualize the geometry below the ground?
I didn't find any example which can do that, in every example the camera stops at the ground level. or we have to load the model always above the ground to visualize it in ArcGIS?
RickeyFight
MVP Regular Contributor
Shree P
"Navigate below ground
Because Ground represents the surface of the earth, you can apply navigation rules to it. By default, navigation below ground is disabled. It is often unnecessary to go below ground and can be disorienting when you go there by accident. If, however, your scene contains data that correctly belongs underground—such as subsurface utility pipes or geological features—you can enable below-ground navigation. In this mode, the height list in the lower corner of the scene view shows negative values when you're below the ground surface. You can enter negative numbers directly, such as -100m, to navigate the camera vertically below the surface.
To enable navigation below ground, follow these steps:
  1. In the Contents pane, choose the Ground elevation surface.
  2. On the Appearance tab, check the Navigate Underground checkbox."
Elevation surfaces—Properties of maps | Documentation
