Hi Everyone,
I have a point cloud that was made from a drone flight using Pix4D. The point cloud will not display in ArcGIS Pro. I can see there are points in the file, it has elevations, but nothing showing up. The TOC shows Data percentage: 0.
I ran CheckLAS and I get the following:
Esri CheckLAS (v1.0.1) Report
Input: C:\Users\JustinJohnston\Documents\ArcGIS\Projects\Midland Cemetery\Pix4D\2023-03-13 Update\2_densification\point_cloud\Midland Cemetery_group1_densified_point_cloud.las
Output: C:\Users\JustinJohnston\Documents\ArcGIS\Projects\Midland Cemetery\Pix4D\2023-03-13 Update\2_densification\point_cloud\CheckLAS
Scan points: YES
Start time: 16:17:09 (2023/03/22)
Elapsed time: 0.326 seconds.
Files Processed: 1
Points scanned: 12,451,312
Problem files detected: 1
>>> File: C:\Users\JustinJohnston\Documents\ArcGIS\Projects\Midland Cemetery\Pix4D\2023-03-13 Update\2_densification\point_cloud\Midland Cemetery_group1_densified_point_cloud.las
WARNING 1: Sum of point counts by-return (0) not equal to point-record count (12451312)
WARNING 2: 12451312 points have return-number 0
WARNING 3: 5 points have outside bound coordinates
Header: xMin = -8552417.892837524, yMin = 4900386.969009399, zMin = 452.473678589
Points: xMin = -8552417.892999999, yMin = 4900386.969000000, zMin = 453.671000000
Header: xMax = -8552088.845275879, yMax = 4900691.848876953, zMax = 532.545867920
Points: xMax = -8552088.845000001, yMax = 4900691.849000000, zMax = 532.546000000
Anyone have a clue what the problem is here and what I can do to get the points to be visible?
Cheers,
Justin
