Layout export failed in ArcGIS Pro 3.1.0
216
04-03-2024 09:25 AM
JamiePearlstein
I am unable to export a layout in ArcGIS Pro 3.1.0. I keep getting the message "Export Failed."
I have read some posts here on this subject, and do have the color management enabled. I am using display filters, but I don't see how that would affect exporting the layout. I don't know what  ".NET Desktop Runtime" is,  and don't know if this is still affects exporting.
Thanks for your help,
Jamie
Robert_LeClair
Esri Notable Contributor
Hi Jamie - what format are you exporting to?  If JPG, then this technical support document may help - Problem: Unable to Export Layouts to JPEG Files in ArcGIS Pro (esri.com)
JamiePearlstein
Hi Robert,
Thanks for your reply. I need to export the layout as a PDF but I will take a look at your document, as it may help in the future. 🙂
Robert_LeClair
I believe this is BUG-000157970 - "Export layout results in an error “ Export Failed” using ArcGIS Pro 3.1 and above" and was resolved at ArcGIS Pro 3.1.2.
Are you able to update ArcGIS Pro to a higher version?  This will likely fix the export issue.
