There is no such toggle, neither in the single layers properties, the properties of the map or in the tool.
As you can see in the attached image the filename is correct, but making displayname equal to filename doesn't seem straightforward.
All modeloutput is displayed like this, changing the filename from 'Sorted%Name' to '%Name%Sorted' doesn't change anything.
Adding the files from windows explorer displays the names correctly.
