Modelbuilder
255
01-15-2020 06:03 AM
MarkBalman
Hi All
I am using the Iterate feature selection to output multiple shapefiles from a geodatabase layer which works well and all files go into a single folder. Essentially, the files are named using a species name attribute e.g. %value%
I would like to know is it possible to add to this model that instead of copying the shapefiles into a single folder, it copies these shapefiles to specific folders that is another field in the shapefile - in this case the Family name of the species e.g.
Corncrake = species name for the shapefile
Rallidae is the attribute for the Family Name field in the corncrake shapefile
then copy corncrake into a folder called Rallidae
Many thanks for any suggestions
Mark
Tags (1)
