Hi @asmith_tssw.,
Depending on the method, either python or arcade, you can easily achieve this. You can do something like this:
Python:
Code Expression:
!Concatenation( FieldA , FieldB , FieldC, etc... )!
Code Block:
def Concatenation( FieldA , FieldB , FieldC, etc... ):
Values = [FieldA , FieldB , FieldC, etc...]
ConcatNonNullValues = ''.join([ x for x in Values if x is not None ])
return ConcatNonNullValues
Arcade:
var ValueList = [ $feature.FieldA , $feature.FieldB, $feature.FieldC, etc... ]
var ConcatValue = ''
for ( var index in ValueList ){
ListValue = ValueList[ index ]
if ( IsEmpty( ListValue ) == False ){ ConcatValue + ListValue }
return ConcatValue
You can use several arcade functions to make the code above easier, but it depends on how you want to go about it.
Feel free to play around with the code above. It should work for what you need or at least point you in the right direction.
