Need a tool to run one layer vs against another layer ?
195
03-26-2024 03:06 PM
PROBERT68
I do have a question for you out there that worked on it before. So my question is that I have two layers of the same feature class. One of them is PBS(Primary Base Series) layer and the other Layer is from GNIS... So both look the same but I wanted to run and check which one does not there and the other is there.
Which tool should I use to run this ?
Tags (3)
PROBERT68
Thank you, Mr GIS King !
