New Locator's Metadata doesn't move with the Locator
668
5
01-28-2022 09:14 AM
MaureenKerr
Hi
I have created a few new Locators on Pro 2.6.8 and added Metadata to them, but when I take a copy of the Locator and paste it into a different folder the Metadata disappears from the Copy. I tried the same with a FGDB and it copied over fine
The reason for all this moving is that I want to update a scratch version then move it in and replace the live version with.
Has anyone experienced anything like this before or can give me some hints as to where I might be going wrong in the Metadata creation process?  I just right click, Edit Metadata, then make my edits in the new window then Save Metadata a the end.
Any help would be appreciated.
Maureen
Tags (3)
ShanaBritt
@MaureenKerr This seems like a bug and the only workaround from an automated standpoint is to use standard Python to copy the metadata xml file associated with the locator (.loc, .loz).
ShanaBritt
@MaureenKerr Which tool did you use to build the locator you created metadata for? Are you copying and pasting in Windows File Explorer or using the Copy geoprocessing tool?
MaureenKerr
Hi Shana I used the Pro Create Locator Tool and I was copying and pasting the Locator within the Pro Catalog from one folder to another. Thanks for coming back to me
MaureenKerr
I should add I intend to automate the update of these locators and will be using ArcPy.Copy_management tool
ShanaBritt
MaureenKerr
Sorry for not getting back to you, Thanks for your help I think you are right I'll report it as a bug and maybe alter the python script for now.  Thanks again
