According to this ESRI article, Overwrite a web layer, it appears that only the owner of a web layer can overwrite it within ArcGIS Pro. This seems like this could be problematic for our GIS team at my organization. We currently run ArcGIS Enterprise 10.6.1 (federated) and I am one of the Portal administrators. We have a small number of Portal admins that need to be able to republish/overwrite any of our map services whenever necessary to help support our GIS team's web apps. Why doesn't a Portal administrator have the ability to overwrite all web layers within Pro? Correct me if I am wrong, but isn't the overwrite a web layer tool essentially the same as republishing a map service within ArcMap? We republish each other's services all the time within ArcMap, so I assumed the functionality would be there in Pro by now. The only workaround I see currently is to go into Portal and change the owner of a web layer to myself, which then gives me the ability to overwrite the web layer within Pro. Is that the only solution right now? Any idea if this will change in future releases of ArcGIS Pro?
