I have repetitive samples at the same locations collected in Survey123. I have a map with symbolized point features for those locations in ArcGIS Pro linked to the feature service for the 123 data.
Is there a way in ArcGIS Pro to set the drawing order on the point shapefile, so it is draws the points by the date field, with the newest date on top? By default it seems to put them in order of object id, which is a problem if they are not entered in order into Survey123. This a constantly updated feature service so I cant do a sort and create a new shapefile every time.
