Good afternoon. I am using PRO 2.6. I have been trying to find a way to add point data to a line with z values to then include as a break line in a TIN that is being created from a LiDAR raster.
The points that I have were taken using an RTK source along a levee. The heights are between 45 and 53 feet.
The line is the center of the levee and/or floodwall. The line has it's own z value of between ~20 feet to ~47 feet, which coincides with the height of the raster.
I am not having luck with taking the heights from the point data and adding it to the line and then also being able to interpolate the height between the points along the line. So if one point is 50' and the next point is 48', being able to show the height gradually lowering to 48' rather than just dropping off at that point.
I then need to create that line as a break line in the TIN in order to determine if the height of the floodwall is sufficient to not allow a flood to come over the top.
Thank you.
