Using ArcGIS Pro 2.4.3. I'm attempting to create a project package that is connected to an enterprise database (Oracle or postgres). The aprx was created with no user/password saved, so that credentials have to be entered each time the aprx is opened. When I attempt to publish this project I am prompted for a Database connection username and password as expected. When I enter a username and password and hit Ok, a new Database dialog comes up (this continues every time I hit ok. If I cancel a message saying "Failed to connect to the specified server." Then the Share Project Package fails.
I checked the logs on our postgres server and it doesn't seem to even try to connect. On a co workers machine the Database connection dialog doesn't come up but the process fails.
Error message: ERROR 001707: Data cannot be opened: SDE(SERVER=development;INSTANCE=sde:oracle11g:development;DBCLIENT=oracle;DB_CONNECTION_PROPERTIES=development;PROJECT_INSTANCE=sde;VERSION=SDE.DEFAULT;AUTHENTICATION_MODE=DBMS)
Should we be able to create a project package without storing a username and password? arcgispro 2.4 project package
