Querying mosaic and LAS datasets footprints
369
11-29-2022 12:17 AM
TomGeo
Occasional Contributor III
I need to analyze the area covered by some polygons. The analysis are based on mosaic and LAS datasets.
Since the mosaic/LAS datasets contain several thousand raster and las files it seems to take ages to do the analysis.
For example, to create my workflow I used a minimal subset of the LAS files to create a LAS dataset and the *StackProfile* analysis went within seconds. Now that I have more las files building the LAS dataset it takes 2 minutes to do the analysis.
Hence, I was thinking to use the polygon to identify the files of the mosaic/LAS dataset intersecting with the polygon, extract their name (or better source path) and create smaller mosaic/LAS datasets on-the-fly.
Can somebody help me out on how to query a mosaic/LAS dataset for the footprints and get the footprint name or source path returned?
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
