Question on symbol I worked on from ArcGIS to Pro: How to ?
525
09-27-2017 02:01 PM
PROBERT68
Any ideas how do I get the symbol change to parallel with the text numbers ? Actually, I set them up in ArcGIS 10.3.1 and rotate the symbol box to 90 degrees along with the numbers.
  1 )See here and this is from ArcGIS 10.3.1
2) Now it is the same thing but it is in ArcGIS Pro 2.0 . How do I rotate the box symbol to 90 degrees here in Pro 2.0 ?
Ugh ?????????
PROBERT68
So I have figure it out .
Here is how to fix this..
1. Bring that layer in ArcGIS Pro.
2. Active your view indicator to Map
3. In the contents, ensure you change to "Labeling"
4. Click on the layer to highlight it.
5.If you see Default under the layer, then you need to create a new label class.
6.in the Class, you need to hit the down arrow to create a new label class.
7. Turn off Default and turn on the new label class.
8.Highlight on the new label class and right click on Labeling Properties to open it if it has not open yet..
Here is an example of what I did.
