"TypeError: cannot alter multipart geometry type" when trying to create singlepart polygons
1086
07-21-2023 04:18 AM
Labels (3)
IlkaIllers1
Hello all,
I have a table which has a field with coordinates in the format (x1,y1),(x2,y2),(x3,y3),(x4,y4),(x5,y5) which I want to convert into polygons. At first, I tried it manually by typing into the python window:
coordinates = [(x1,y1),(x2,y2),(x3,y3),(x4,y4),(x5,y5)]
with arcpy.da.InsertCursor(output_fc,["SHAPE@"]) as cursor:
    cursor.insertRow([coordinates])
This worked fine but is for obvious reasons a lot of work to do separately for every single polygon. So I tried to get it done in one go:
iCur = arcpy.da.InsertCursor(output_fc,["SHAPE@"])
with arcpy.da.SearchCursor(search_fc,"COL_A") as sCur:
    for row in sCur:
        iCur.insertRow([row[0]])
This results in "TypeError: cannot alter multipart geometry type".
I don't understand why it thinks this is supposed to be a multipart geometry. My thinking was by iterating through the sCur with the for loop, it would take only one row at a time (which is confirm when I print(row)). This works as an input manually, why does it not work within the cursor and loop?
DanPatterson
polygons require input Point objects, check the associated syntax in the help files
Write geometries—ArcGIS Pro | Documentation
... sort of retired...
IlkaIllers1
Yes, that page is where I got the idea from. At the very bottom the examples show how to construct a polyline from just pairs of coordinates. I tried that for polygons and as I mentioned it works as long as I manually input the coordinates for every polygon separately - without using arcpy.Point. I feel like I am missing something? Why does this work:
but it doesn't when I try to retrieve the same input from a search Cursor? I checked with the print function, and
with arcpy.da.SearchCursor(search_fc,"COL_B") as Scur:
    for row in Scur:
        coordinates = row[0]
        print(coordinates)
 gives me exactly the same; namely:
If that is the return from the search cursor, why does it not work as input  for the insert cursor?
DanPatterson
coords = [[0.0, 0.0], [2.0, 8.0], [8.0, 10.0], [10.0, 10.0],
          [10.0, 8.0], [9.0, 1.0], [0.0, 0.0]]
arr = arcpy.Array([arcpy.Point(*i) for i in coords])
type(arr)
<class 'arcpy.arcobjects.arcobjects.Array'>
poly = arcpy.Polyline(arr)
type(poly)
<class 'arcpy.arcobjects.geometries.Polyline'>
IlkaIllers1
But that is again just for one polygon. That works without the array as well. If I try to do it for all polygons with the search Cursor
with arcpy.da.SearchCursor(search_fc,"COL_A") as Scur:
    for row in Scur:
        arr = arcpy.Array([arcpy.Point(*i) for i in coordinates])
        poly = arcpy.Polygon(arr)
        iCur.insertRow(poly)
I get the following traceback:
File "<string>", line 5, in <module>
File "<string>", line 5, in <listcomp>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\arcobjects\mixins.py", line 1101, in __init__
setattr(self, attr, value)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\arcobjects\_base.py", line 109, in _set
return setattr(self._arc_object, attr_name, cval(val))
RuntimeError: Point: Input value is not numeric
