Hi all
Totally new to ArcGIS Pro and ESRI in general. I have used GIS products before though so understand the concepts.
I would like to create a Live dashboard in ArcGIS online, the data i have is in a SQL view in our Incident database. The view i created has the Easting and Northing fields but it's a not a spatial database (is that a problem?).
I would like to import the data into ArcGIS pro and publish it to ArcGIS Online as a live web layer that refreshes every 10 minutes. Or if it's possible, can this be done directly in ArcGIS online?
I have attempt this by;
- In ArcGIS Pro I created a new database connection and added the SQL view to the current map.
- The SQL view has Eastings and Northings and there is no Spatial Index on the incident tables in the database that I know of, so I am concerned that this is what’s causing the issue.
- I then tried to create a XY Event Layer but it didn’t recognise my Easting and Northing fields, it didn’t even suggest them in the drop downs.
I also tried to import it through the Data Interop extension quick import tool.
I can get the data to map points but when i set the refresh rate of 10 minutes it doesn't work. Even if i manually force the refresh. It appears to be a static table once imported.
What am i doing wrong? Any advice or suggestions welcome.
thanks
