Removing Zeros From a Field
10852
7
03-14-2019 01:17 PM
MichelleCouden
Anyone remember how to remove zeros from in front of a number in a field. For example, I have 00012. I want 12.
I forgot the formula in the field calculator.
Robert_LeClair
Esri Notable Contributor
I found this bit of code on the Microsoft Community page that should work in the Field Calculator using VBScript:
Assuming there is no space character in the data:
Replace( LTRIM(Replace( fieldName, "0", " ")), " ", "0")
The part in bold replace all zeros by spaces, and then, left-trim that result, ie, remove starting spaces. The external Replace replaces the spaces left in the string to their initial 0 character.
JoeBorgione
In python you can use:
!field_name!.lstrip('0')
That'll strip off any leading zeros:
MatthewDuffy
Occasional Contributor II
Thank you Joe Borgione, this is helpful and I remain grateful for your input
MatthewDuffy
Used to be that we could simply multiply the text as a number by 1
so
000012 x 1 = 12
Trying to find out what this might look like today from within ArcPro is up to you
JoeBorgione
This thread popped up in my activity log today. You can do the same calculation in pro as I described above or use the int() function :
 I guess the int() function would have worked originally too....
DavidWheelock2
Is there an Arcade solution?
JoeBorgione
Don't know offhand:  check here and take a look...
