Hello all,
I have an issue when running the Sample tool (Spatial Analyst Tools).
I have added below the contents of the error message so you can have a look.
The very strange thing is that the tool runs and does not run into any issue if I tick the "Generate Feature Class" box. I would like to understand what is happening and why do I get an error if I want to get it directly as an output table.
Any help will be much appreciated,
Cheers
Sample
Parameters
Input rasters Dist_Coast
Input location raster or features pa_raster_pro
Output table or feature class C:\Users\cynth\Desktop\SDM_2021\SDM_data\Model_data\test
Resampling technique NEAREST
Unique ID field VALUE
Process as multidimensional CURRENT_SLICE
Acquisition information of location data
Statistics type
Percentile value
Buffer distance field or value
Column-wise layout ROW_WISE
Generate feature class TABLE
Messages
Start Time: 09 November 2021 15:22:26
ERROR 010555: Internal error in Sample: %s.
Failed to execute (Sample).
Failed at 09 November 2021 15:22:26 (Elapsed Time: 0.27 seconds)
