I have a script tool that takes a feature layer and update the table with
'arcpy.da.UpdateCursor(path, fields_rec) as cursor:'
It runs on shp files from my geodatabase but i want to make it run also on a web feature layer that i upload from the organization portal, is it possible ?.
I am new to the AGOL field and possibilities.
Here is the code for refernce:
import arcpy import os import time arcpy.env.overwriteOutput = True arcpy.env.workspace = r"C:\GIS\###\x_prebuild.gdb" # Choose receivers layer and input lists for surveyour and restored status rec_table = arcpy.GetParameterAsText(0) surv_list_str = arcpy.GetParameterAsText(1) Feature_rec = os.path.basename(rec_table) surv_list = surv_list_str.split(",") fields_rec = ["LineNumber", "Station", "Status", "Surv_Date","Restored_Date"] # Update Status for Rec layer - SURVEYED i=0 for x in range(int(len(surv_list)/3)): with arcpy.da.UpdateCursor(path, fields_rec) as cursor: for row in cursor: if row[0] == surv_list and row[1] >= int(surv_list[i+1]) and row[1] <= int(surv_list[i+2]): row[2] = 1 row[3] = time.strftime("%d/%m/%Y") cursor.updateRow(row) i += 3
