Hi all,
I have the following challenge.
- 1 building footprints (800.00 records)
- 1 state-wide layer (50 records showing 50 subareas)
I want to select/delete all building footprints that fall within one subareas polygon in the state-wide layer. It sounds so easy but I can not find the right tool.
The SQL code would look like this.
Select all polygons that are within the subarea xyz of layer state-wide (the second polygon layer)
Any ideas please?
Thank you!
To all - I found the solution myself ! 🙂
I did a def query to filter on this one specific record in the def query and then I used the select tool. This combination works.
What about select by location tool?
https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/select-features-by-location.htm
Hi Johannes,
The select tool is a good start, but I can not set the condition of using only one record. I can set the relationship between the two layers, meaning intersect, or within or contains etc. This mean the whole dataset is considered and not just one record.
What I am after is that only one record will be used (of 50 in total). For example, select all building footprints of layer 1 and then delete all those building footprints based on an bigger polygon overlay of a single record of layer 2. -> Delete all building footprint in a selected polygon that contains all the single building footprints of layer 2.
The Select tool allows me to set a distance only. Should I use this?
Any ideas please?
