Select Only Valid Objects
250
11-21-2021 05:27 PM
Labels (2)
StefanDieters1
New Contributor III
Pro 2.8, Enterprise 10.9. I  am using web layers from portal. I am trying to use "Select Only Valid Objects" option. It pauses and runs but does not return any results. I have the editor option "Enforce Attribute Validation" set on. I have an attribute  validation rule set on my layer. This rule works as I can use the Error Inspector to find existing features that fail this rule.
How does "Select Only Valid Objects" work?
What is an invalid object?
Any ideas why it is not selecting features that fail validation rule.
Here is the link to the documentation: https://pro.arcgis.com/en/pro-app/latest/help/editing/edit-feature-attributes.htm#ESRI_SECTION1_8F13...
