The issue is not with the software but with the shapefile format - which has not changed.
Shapefiles do not contain an x,y tolerance as do geodatabase feature classes. x,y tolerance is the minimum distance between coordinates before they are considered equal. This x,y tolerance is used when evaluating relationships between features within the same feature class or between several feature classes. It is also used extensively when editing features. When using any operation that involves the comparison of features, such as tools in the Overlay toolset, the Clip tool, the Select Layer By Location tool, or any tool that takes two or more feature classes as input, use geodatabase feature classes (which have an x,y tolerance) rather than shapefiles.
I would add that if you do overlay shapefiles, it is a good idea to set the XY Tolerance environment to avoid unnecessary issues. I believe shapefile coordinate precision is only 32 bits, and since they are floating point (not integer like geodatabases), these are approximations so the "fuzzy creep" your translated quote alludes to can be a real issue over multiple overlay operations.
Your post title is talking about something else, which is also an important thing to know, about shapefile table (.dbf format) fields:
Unlike other formats, shapefiles store numeric attributes in character format rather than binary format. For real numbers (that is, numbers containing decimal places), this may lead to rounding errors. This limitation does not apply to shape coordinates, only attributes.
ArcGIS Pro Help: Geoprocessing considerations for shapefile output
