Spatial Join and Select By Location - Getting Different result count
134
3 weeks ago
Labels (2)
RavindraSingh
1. When I do Spatial join between two Polygon feature classes with below parameters, then i get 8 number of records as result:
  • Target Features - Polygon feature class-1
  • Join Features - Polygon feature class-2
  • Output feature class-  .gdb path with file name
  • Join Operation - 'Join one to one'
  • Keep all target features - unchecked
  • Match Option - 'Are Identical to'
  • Search radius - blank
2. When I do Select By Location Operation with below parameters, then i get 10 number of records as result:
  • Input Features - Polygon feature class-1
  • Relationship -  'Are Identical to'
  • selecting features - Polygon feature class-2
  • Selection Type - 'New Selection'
  • Invert Spatial relationship - Unchecked
Ideally I should get same result, since Relationship I am using is  'Are Identical to'.
Please through some light here.
DuncanHornby
MVP Notable Contributor
Looks like you have found a possible bug in Arcpro and how the different tools reconcile the relation Are Identical to. I would say you should edit your question and include the test data as a zip file for people to test to see if others can replicate the issue and discount if it is a hardware issue.
