I use text formatting tags to get different text sizes within one label. The Problem ist, that there is a "&" in some of my name-attributes. It seams, that these "&"-characters are interpreted as part of the formatting tags. Is there a possibility to tell ArcGIS Pro Framework, that the "&" should not be interpreted as part of the formatting tags?
(It would not be a problem to write a exclusion-tag into my name-attribute field, since I only use them for labeling.)
My Label Expression is:
$feature.NAME + "\n" + "<FNT size= '12'>" +"(" + $feature.NUMBER + " TEXT)" + "</FNT>"
$feature.name containes the "&" character in some cases. In these cases the Lebel in the maps is:
"NAME" <FNT size='12'>(NUMBER TEXT)<\FNT>
So the tags are part of the shown labels and the part which has the Lebels appears two times there.
Does anybody know a solution or a hint, what I can try to solve the problem?
Thanks
David
