Hello Christine Leslie, Jason Camerano, Amir Bar-Maor,ArcGIS Pro Tasks team and ArcGIS Pro team.
I am attempting to use the "Additional Actions" capability of Tasks to both copy attributes and calculate fields either side of an Append function. However, neither are performing as expected. Here are the steps within my task:
- Select several points in Featureclass A, to be Appended into Featureclass B
- Append the selected points from A to B. Within the Append parameters I set:
- Input Layer to Featureclass A (including a selection set of features within this Featureclass)
- Target Dataset to Featureclass B
- {location} field of Target to get fieldmapped with {VALVE_NO} of Input (this is a unique ID field)
2a. Additional Action when exiting the step to Calculate Field values into only the Features or records created in this step - ie: only those points just appended to this layer in this step.
Although the Append from step 2 works, the field mapping to pass {VALVE_NO} into {location} fails to occur. Further, the Additional Action supposed to occur at the end of the step to field calculate values into the fields of the features just appended also fails and gives me the below error:
Please can someone point out where I'm going wrong?
Thanks
