Hi. As seen in the video attached, I'm attempting to make a time-enabled animation utilizing two layers (Polyline, Point). It is possible in ArcMap to set each layer's "Display Data Cumulatively" options individually (as shown in the JPEG file for Point & Polyline settings in ArcMap). But in ArcGIS Pro, I'm unable to accomplish that. When I drag the slider to the "Display Data Cumulatively" setting in ArcGIS Pro, the adjustments are applied to both layers and the data is shown cumulatively. Point data must advance according to the schedule (without cumulative) and polylines must advance using the cumulative option. How to use ArcGIS Pro to instantly apply the settings for two layers. Kindly recommend..
